mcbuggin
« Reply #1 on: November 17, 2009, 05:55:47 AM » |
on caraudioclassifides there is a set of RE components that will work well
Logged
mcbuggin
« Reply #2 on: November 17, 2009, 06:02:49 AM » |
Logged
sinsear
« Reply #3 on: November 17, 2009, 07:08:33 AM » |
From my experience you will have mounting depth issues with almost any honda when running 6.5" speakers especially in Integra's but it is an easy fix to make some decent spacers. Also I would suggest that you just upgrade your front speakers and fade everything to the front if you have a hatch or coupe seeing as it will give you better sound imaging as well as sound quality IMO. If you just end up upgrading just the fronts this amp is more than overkill for anything you can find out there.
As for speaker brands I am a big fan of the Infinity Kappa Perfect line, Diamond Hex series, Focal makes some killer speakers. What is your price range?
Logged
mcbuggin
« Reply #4 on: November 18, 2009, 08:40:11 AM » |
just useing a front stage is the way to go so i agree with that but I have a set of sound stream components that are getting 150 RMS and the RE set i recomended will take more. just fyi
Logged
sinsear
« Reply #5 on: November 18, 2009, 05:36:09 PM » |
Ya I didn't check the specs on the RE audio speakers and HERRERRERA MAN OF UTAH was talking about using this 2 channel amp on 4 speakers so he would have no fade control (if I am reading correctly) thus killing the imaging. I think that the speakers should influence the choosen amp instead of the other way around.
What is he willing to spend on speakers choose them based on specs Sensitivity Price Wattage etc. Then go choose an amp to compliment the speakers.
Again this is just my opinion on how I would do it again if I started my car stereo over again.
Logged
S.P.Audio
« Reply #6 on: November 18, 2009, 08:33:54 PM » |
I would recommend a nice 6.5 Component Set of speakers. and as far as brand. i will suggest a few brands. but i highly recommend LISTENING to them first. go shop to shop and do some listening. take a cd that you are very familiar with and know every lyric to demo every set of comps you come across. no joke. everyone's hearing band is different. buy what sounds good to you. that's what there for right.. I recommend listening to Pioneer, Alpine, Rockford Fosgate, Memphis, Focal, Hurtz, phoenix Gold. just go listen! I think the t-600 is a perfect front stage amp! im shooting for around 1k watts front stage in my teg! it will give you plenty head room. and clean power. but it MUST be tuned right! with a DMM and a sign wave CD. Have the t-600 run the front stage 6.5'' 2 way Component speakers of youre choice. Deck power the rear speakers. You're sub stage has MAD potential! make about a 3.5 cu ft ported box for it and those Type R's on the 1000/1 will SIIIING! let me know if you need any help.
Logged
WuddaWaste
« Reply #7 on: November 23, 2009, 02:47:04 PM » |
FWIW, I like Infinity.
Logged
« Reply #8 on: December 03, 2009, 01:34:39 PM » |
Thanks for your help fellas!! i was not able to buy that amp from ebay, and now have a smaller budget to work with.. need new recommendations for amp/ front speaker combo. best bang for the buck around $300 You're sub stage has MAD potential! make about a 3.5 cu ft ported box for it and those Type R's on the 1000/1 will SIIIING!
i used to have a 2 12"s and they just were'nt my style, i got the 10's and the smallest box application was a .82 per speaker, for a clean sharp short thump, but the guy who made my box when with a .68 and i do think its a bit small. it still hits hard, but you think a 3.5 cu ported would allow those subs to reach max potential?
Logged
Don't Kanye me or I will Chris Brown you and Tiger Woods your mother, and R. Kelly on your rug
S.P.Audio
« Reply #9 on: December 03, 2009, 06:44:22 PM » |
Man... those are Type R's they are like the Whore of the Entry level SPL heads. look... this is 1 type R 10'' sub on a 1000 Watt mono amp.
they have alot of potential in Either Box. It all boils down to what kind of music you listen too. either application of box will wang when built right.
Logged
Minion
« Reply #10 on: December 04, 2009, 09:37:15 PM » |
don't listen to these two DB's (seth n mcbuggin).. they have no idea what they're talkin about. my grandma puts together louder setups than these fools. lol..
Logged
  that is soooo going in my sig
no you need to shut the fuck up sir.
FUCK THIS FUCKING BULLSHIT FUCKING PIG COPMOTHER FUCKER GOT PULLED THE FUCK OVER I MEAN I WAS BREAKING THE LAW BUT THAT BITCH FUCKIN PULLED ME OVER CUZ MAH TATTOOS AN SHI BITCH ITS FUCKING STUPID.
WuddaWaste
« Reply #11 on: December 07, 2009, 02:32:00 PM » |
I can't really see the pics here since everything is blocked at work, but here's my two cents.... Subwoofer:1. Small Box. If you think your sealed box was built too small, you can stuff the box with polyfill to make it seem like a bigger box. There of course are limitations to this, but it's been a technique used by speakerbuilders for YEARS and is proven to work. The best part about this is that polyfill is CHEAP (like $3 from Walmart), so your sound improvement won't cost an arm and a leg. For details on stuffing density and such, read this: http://www.audiojunkies.com/blog/1348/ultimate-polyfill-subwoofer-enclosure-resource 2. Ported Box. Using a ported/vented box as opposed to a sealed box will usually give at least 3dB of gain when built correctly. 3.5 cu ft sounds HUGE to me, but it all really depends on the T/S parameters of the driver you're using. That may very well be right. Front Speakers:These other guys are probably your better go-to for the information here's what I would do if I had to build on a budget. 1. Choose your speakers first. As I said before, I like Infinity for bang-for-the-buck. You can pick up some coaxial Infinity Reference speakers for about $50-60 per pair. They're widely used, get great reviews, and I really dig the specs on them. Some of the most efficient drivers on the market! 2. Buy an amplifier based on the speakers you've chosen. If you went with the Infinitys above, they take up to 50W RMS -- so you'll want an amp that puts out at least 2 x 70W RMS just to be safe. In this recession, it's EASY to pick up a steal of a deal on a gently used 2-channel amplifier off KSL or craigslist (or UtahHondas). I'm pretty sure you can pick up an amp like this for under $100. 3. Sound deadener. If you're on a budget, I recommend just buying Peel N Seal from Lowe's. It's technically a roofing product, but it's INCREDIBLY similar material as Dynamat and costs pennies on the dollar. A lot of DIY car audio guys on a budget use this and report great results. Seal your doors with this stuff. You'll probably need a garage or heat gun to make it stick to your door panels in this weather. The stuff isn't very sticky when it's cold. When it's all said and done, this should cost you less than $40 total. 4. You're also gonna need an amp install kit, RCA cables, speaker wire, etc to get the job done. Shop around and I'm sure you can find a decent price for this stuff. Hope that helps.
Logged
mcbuggin
« Reply #12 on: December 07, 2009, 03:08:17 PM » |
LOL
Logged
« Reply #13 on: December 10, 2009, 10:47:09 PM » |
sweetness, thanks a bunch guys i really appretiate the info! im looking to get some kick ass great quality front speakers, whats the reccomendation for atleast 150watts rms, best bang for buck speakers in $100 ea. range..
Logged
Minion
« Reply #14 on: December 10, 2009, 10:48:04 PM » |
alpine type r 6's or 6.5's. . you'll love them
Logged
Minion
« Reply #16 on: December 11, 2009, 02:59:28 PM » |
those are nice.. check these out. not bad price. not a bad speaker. i just really love type r speakers. their subs are an amazing bang for the buck. but these door speakers are sick too. they're what i'm after. http://www.onlinecarstereo.com/CarAudio/p_17562_Alpine_SPR-17C.aspx
« Last Edit: December 11, 2009, 03:06:35 PM by Minion »
Logged
sinsear
« Reply #17 on: December 11, 2009, 09:06:21 PM » |
How much are you looking to spend on speakers?
Logged
S.P.Audio
« Reply #18 on: December 12, 2009, 11:33:58 AM » |
You guys need to know the Diffrence Between Coaxil Speakers and Component Speakers..
I at anytime allways Segest Component speakers in the front doors. and Coaxil Speakers in the Rear.
Logged
sinsear
« Reply #19 on: December 12, 2009, 02:17:07 PM » |
Logged
S.P.Audio
« Reply #20 on: December 12, 2009, 02:54:01 PM » |
Logged
S.P.Audio
« Reply #22 on: December 12, 2009, 09:45:53 PM » |
^i did alot of searching on those, and alot of ppl say they're not the best in mid, and tweets are harsh. but i might pick them up. cant go wrong for $80 especially if it comes with that amp!
one more speaker amp combo i want you guys to comment on.. lmk wyt
UMM THAT'S NOT A AMP! that's a crossover. it is part of the speaker system. make sure there are 2 tweeters. two woofers, and 2 crossovers.
Logged
sinsear
« Reply #23 on: December 12, 2009, 11:02:13 PM » |
I don't know alot about MB quarts amps but MB Quart is now owned by Rockford Fosgate so..... I do love the MB Quart Components I have in my Teg but they do require a lot of tweaking to get them to sound right and the definitely need an amp. As for those Infinities the Kappa Perfect series sounds absolutely great. I have had them in quite a few cars and never once had any complaints about them. And for those Image Dynamics the specs on them look pretty decent but i think the infinity's will sound just as good as them and they are 1/2 the price.
Logged
S.P.Audio
« Reply #24 on: December 13, 2009, 07:13:20 PM » |
RockfordFosgate makes nothing but RockfordFosgate. :period: MB Quart was at one time a Independent Company. they went under. and Maxxsonics bought MB Quarts name. so its no longer truly MB Quart Quality. http://www.maxxsonics.com/What was MB Quart is now German Maestro. http://www.german-maestro.de/index.htmand good luck finding these for cheap. Schooled.
Logged
94_DB8_4dr
« Reply #25 on: December 13, 2009, 10:57:32 PM » |
fuck it!.. jus get pioneer 1 way speakers!... they are SLIM, cheap and sound like SHIT!....
Logged
S.P.Audio
« Reply #27 on: December 14, 2009, 01:29:07 PM » |
nobody in either of thoseforums knows what they are talking about. Rockford has been rockford never changed.. for years. they never bought, or sold anything other then RockfordFosgate.. And MB quart sucks anyways. before. after. now. Focal FTW! http://www.focal-america.com/
Logged
sinsear
« Reply #28 on: December 14, 2009, 01:44:37 PM » |
Logged
S.P.Audio
« Reply #29 on: December 14, 2009, 02:22:14 PM » |
Focal is priced to compete..
i had a set of alpine type X pro comps last year, ran them with a 500.2.. loved em.
Logged
« Reply #30 on: December 14, 2009, 11:20:43 PM » |
after checking out, and learning about some of the speakers out there, i should have snagged those RE's!! urghh. ive narrowed it down to two, type-r and image dynamics ctx65cs help me choose out of the two. which has more potential?
« Last Edit: December 15, 2009, 12:09:38 AM by HERRERRERA MAN OF UTAH »
Logged
94_DB8_4dr
« Reply #31 on: December 14, 2009, 11:32:42 PM » |
diamond audio d6 components are bad ass! too.. hex series are sick as well... n yes focal is priced to compete! id run em..
Logged
mcbuggin
« Reply #32 on: December 15, 2009, 12:49:55 PM » |
get the ctx65cs they are better than the type ahrrrrrrrs
Logged
« Reply #33 on: December 21, 2009, 04:51:48 PM » |
well after a couple weeks of searching, i have finally made my decision.
narrowed it down to Image Dynamics 356cs and Precision Power PPI 356cs
The winner is.................... .............. .......................... ...................... ........................ ............... ............................... ...........
Logged
mcbuggin
« Reply #34 on: December 22, 2009, 05:41:22 AM » |
never heard the ppi but if you get them do a reveiw
Logged
« Reply #35 on: December 22, 2009, 02:23:31 PM » |
oops forgot to put wht a bought, PPI. i'll do a review of my own, it wont be that good, cause i will be comparing them to sony explode walmart special speakers, with an amp i got from auto zone, so i have a feeling they might sound better than that.. but while searching, i came across about 5 different reviews from ppl switching from Image dynamics to PPI, here is one that helped with my decision.. http://www.caraudio.com/forum/showthread.php?t=435657&highlight=356cs
Logged
« Reply #36 on: January 07, 2010, 04:56:47 PM » |
k everythang came today, ive never hooked up component speakers and dont know how to hook up the crossovers, and shiz.. anyone want to come help a mother lover out?
Logged
gsrintegra
« Reply #37 on: January 07, 2010, 05:29:29 PM » |
pm seth he knows his shit
Logged
1999 EBP EM1- DD 2000 PY ITR- Garage Queen
« Reply #38 on: January 07, 2010, 09:50:04 PM » |
nevermind just downloaded the manual.
Logged
« Reply #39 on: January 08, 2010, 12:27:25 PM » |
i havn't installed audio shit for awhile, does look right?
Logged
DustPan
« Reply #40 on: January 08, 2010, 12:53:11 PM » |
Your missing the ground to your battery Kyle. It is all fucked up now.
Logged
CLICK HERE FOR FREE PORN Utah's fastest RUNNING single cam!! Again!! and to dustpan, i have heard through the grapevine you are damn good with hondas and may be able to offer assistance.....
« Reply #41 on: January 08, 2010, 12:55:29 PM » |
lol i would shit myself if that was the only thing i forget. i'd probably throw everything away thinking nothin worked
Logged
S.P.Audio
« Reply #42 on: January 08, 2010, 06:05:23 PM » |
looks like a cartoon.
Logged
mcbuggin
« Reply #43 on: January 12, 2010, 05:45:44 AM » |
seth is closer but if you need the help and want to come to logan i'll help ya
Logged
« Reply #44 on: January 12, 2010, 09:51:46 PM » |
thanks, but its all done. its loud...if i turn volume up i would go deaf before the speakers start to destort.
Logged
S.P.Audio
« Reply #45 on: January 14, 2010, 11:30:28 PM » |
niiice.
Logged
