UtahHondas.Net | Home of Utah's Honda and Acura Enthusiasts
July 29, 2010, 08:38:36 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: There has been a Memorial Fund account setup for Billy Payne @ Wells Fargo the account is #7090982245.
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Injectors?  (Read 176 times)
bipolarone
Forum Member
Offline Offline
Email
Ignore
« on: February 23, 2010, 07:52:46 AM »
Ls boosting 12 pounds, what are the most efficient injectors to run?
Logged
DustPan
Vendor
Moderator
Offline Offline
Gender: Male
dustpan16@hotmail.com
WWW
« Reply #1 on: February 23, 2010, 04:07:28 PM »
750cc or 1000cc ID saturated. You can go cheap and buy used 450cc or bigger peak and holds but your car will run better with saturated injectors.
Logged
CLICK HERE FOR FREE PORN
Utah's fastest RUNNING single cam!! Again!!
and to dustpan, i have heard through the grapevine you are damn good with hondas and may be able to offer assistance.....
runsnines
CG Racing
Vendor
Offline Offline
Email
Ignore
« Reply #2 on: February 24, 2010, 12:23:49 AM »
You cant base injector size off of manifold pressure. How much hp are you trying to make? I have a couple cars making 485hp on 12 psi and others making 250hp on 12psi so injectors size is based off of airflow not pressure.
Logged
bipolarone
Forum Member
Offline Offline
Email
Ignore
« Reply #3 on: February 24, 2010, 07:57:10 AM »
on this motor, probably around 240-260?
is that a lot on a ls with stock internals?
Logged
runsnines
CG Racing
Vendor
Offline Offline
Email
Ignore
« Reply #4 on: February 24, 2010, 08:16:16 AM »
Ok, cool . 440cc or bigger will be fine. Make sure you have a good walbro 255 fuel pump to go with it.
Good luck sir, if you need anything let Dustpan or me know.
Logged
bipolarone
Forum Member
Offline Offline
Email
Ignore
« Reply #5 on: February 24, 2010, 09:12:14 AM »
Cool thanks man!
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
