UtahHondas.Net | Home of Utah's Honda and Acura Enthusiasts
July 29, 2010, 08:20:55 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: We are now setting up vendor sections here on the site. If you are a reputable local business with interest in this said service, send Ran or Teknik_DC2 a PM.
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: transmission help.. car wont roll  (Read 123 times)
iTbAgHoEs
Forum Member
Offline Offline
Gender: Male
Email
Ignore
« on: March 10, 2010, 10:32:41 PM »
just finished swappin my motor, went to pull out of the driveway and i noticed that when i tried to get the car to coast down the driveway it would just stop. at first i though that one or more of my brake calipers had seized. the car was sitting for a while. but after checking i found out they were all spinning free. the car just wont roll and the resistance is coming from the front. the transmission works fine and hits every gear. the clutch is actuating fine.
when the front of the car is off the ground both tires spin freely and in opposite directions. if one side of the car is down its becomes very difficult to spin the side that is off the ground. that might be typical, i don't know.
its a gsr transmission. please let me know if you have any suggestions. feel free to call or text...801-682-6183
*UPDATE*:   what are the symptoms of a broken differential??
« Last Edit: March 11, 2010, 10:47:36 PM by iTbAgHoEs » Logged
DustPan
Vendor
Moderator
Offline Offline
Gender: Male
dustpan16@hotmail.com
WWW
« Reply #1 on: March 11, 2010, 09:27:19 AM »
Sounds like your transmission is locked into gear or something. Pull the spark plugs and see if it rolls easier.
Logged
CLICK HERE FOR FREE PORN
Utah's fastest RUNNING single cam!! Again!!
and to dustpan, i have heard through the grapevine you are damn good with hondas and may be able to offer assistance.....
Ninja
Juggalette
Event Planner
Offline Offline
Gender: Male
The Great CRX HOAX!
Ignore
« Reply #2 on: March 11, 2010, 09:56:11 AM »
Are you swapping this into a EF (CRX/Hatch)?  If so, you need to remove the dust caps from the backside of the knuckle.
Logged
DustPan
Vendor
Moderator
Offline Offline
Gender: Male
WWW
« Reply #3 on: March 11, 2010, 10:02:23 AM »
Sounds like the axles spin ok though.
Logged
Ninja
Juggalette
Event Planner
Offline Offline
Gender: Male
The Great CRX HOAX!
Ignore
« Reply #4 on: March 11, 2010, 10:06:37 AM »
still could be a problem if the axle nut is loose.  There wouldn't be any pressure against the hub.
I'm purely assuming from my personal experience though, and giving suggestions.
Logged
OregonTransplant
Forum VIP
Offline Offline
Gender: Male
Ignore
« Reply #5 on: March 11, 2010, 11:40:58 AM »
I shattered my final drive and the same thing happened. The car would roll about 6 feet foward and then it would stop.
Logged
iTbAgHoEs
Forum Member
Offline Offline
Gender: Male
Email
Ignore
« Reply #6 on: March 11, 2010, 12:38:09 PM »
i did have to tighten the axle nuts by hand.. gonna hit em with the impact see if that helps.
btw its just an LS into an em1.
i dont think the trans is locked into a gear. you can move the car with the power of the motor, just cant push it, and it stops dead as soon as you let off the gas.
Logged
lopezpslc
Forum Regular
Offline Offline
Ignore
« Reply #7 on: March 13, 2010, 10:25:47 AM »
just get a new transaxle there cheap
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
