Author Topic: B16 jumps timing  (Read 1773 times)
Offline fritter critter
B16 jumps timing
« on: June 19, 2011, 10:14:25 PM »
So I recently got my head machined and all put back together, rotated the crank mutiple times to check my timing marks to make sure they were on and tried to drive it to work and it jumped timing on me. On closer inspection it looked a little loose so I redid the timing on it again and put a screwdriver on the tensioner to sorta take out the extra slack, which worked and rotated mutiple times again to check timimg and made sure to tighten the tensioner and started it and drove home. Started to drive it again today and jumps timing again. My belt is still tight and don't feel play in the tensioner. I'm using the same timing belt I used before I got the head machined and have ran out of ideas of what may be wrong. Any ideas of what's wrong will be greatly appreciated.
Re: B16 jumps timing
« Reply #1 on: June 19, 2011, 10:17:06 PM »
Oh forgot motor info, B16A2 block, jdm B16 head, stock headgasket, arp studs, stock cam and cam gears
« Reply #2 on: June 19, 2011, 10:19:17 PM »
Old/stretched timing belt?  Faulty tensioner?  Those are the most common things that cause a belt to jump.
« Reply #3 on: June 19, 2011, 10:21:15 PM »
Is there a way to check a tensioner to see if its faulty?
Offline Ran
  • Compulsive Gambler
  • Admin
« Reply #4 on: June 19, 2011, 11:55:29 PM »
was your head milled at all?
Four Door Mafia
'00 Integra LS sedan
'05 Lancer Evolution VIII MR
Breaking and fixing shit since 2004
Until We Meet Again My Friend -- Billy Payne -- 11/11/1980 - 6/22/2010 -- Rest In Peace
« Reply #5 on: June 20, 2011, 07:40:04 AM »
Yes it was milled, how much not sure
Offline thefirstPACT
  • Old Guy Car Club
    • Fighting Out Of
« Reply #6 on: June 20, 2011, 08:02:55 AM »
those tensioners aren't hydro so it should just bolt down. How is your dizzy? Does it spin freely? If it doesnt that could be a culprit as well.
WWW.FIGHTINGOUTOF.NET
UTAH'S ONLY MMA NEWS WEBSITE!
lovindaem1:BUT MY CRX IS CALUBRADED SOMETHING LIKE THAT
« Reply #7 on: June 20, 2011, 11:44:44 AM »
I will check but I popped my hood yesterday night and I can tell vy looking at the cam gears the timing is off, by how much I can't tell
Offline Ran
  • Admin
« Reply #8 on: June 21, 2011, 12:09:45 AM »
I had my motor jump timing when I stuck the dizzy in 180 degrees around. :-\
Four Door Mafia
« Reply #9 on: June 21, 2011, 08:03:13 PM »
Ok took the dizzy cap off and the rotor does not spin, but on closer inspection, number 3 cam cap was on backwards (I didn't do it, a friend who helped did and I didn't check his work). Would that cause it?
Offline Thefastest4dr
  • Forum Transvestite
« Reply #10 on: June 21, 2011, 08:37:32 PM »
It could have caused it. Are the cam caps over torqued?
10.85@141mph CGtuned
"It's either blue cheese with wings or go fuck your mother." ~ Joey "Coco"  Diaz
« Reply #11 on: June 21, 2011, 09:29:01 PM »
The ones that can fit with a long socket yes, the 4 that also act as valve cover bolts were hand tightened
« Reply #12 on: June 21, 2011, 09:41:41 PM »
Dammit dane!! I should of came over and supervised.
« Reply #13 on: June 21, 2011, 10:01:00 PM »
Ha ha I know right? See what happens when I work by myself?
