Author Topic: car wont turn over  (Read 1640 times)
Offline CIA
car wont turn over
« on: February 14, 2013, 11:04:32 AM »
So my car won't turn over it just clicks. I've replaced the starter and main relay and im still getting the same result. Any other suggestions? The battery is only 3 months old and terminals are clean.
Offline 89ef
Re: car wont turn over
« Reply #1 on: February 14, 2013, 05:37:48 PM »
Charge the battery put it back in drive it to AutoZone and they will test your alternator you can also check alternator fuse
1991 GSR Civic Wagon winter project
1988 RT D16Z6 Civic Wagon sold
1990 CR-X Si summer in storage sold
1990 CR-X Dx Torino Red
1991 K24 CR-X Si under construction
1994 Del Sol new daily honda #16 and counting
Offline FoUrDoOrWhOrE
  • ISS Volunteer
  • Forum Whore
car wont turn over
« Reply #2 on: February 16, 2013, 12:09:18 AM »
Charge your battery if you don't have a charger take it to autozone it takes an hour or so then put it in your car if it starts pull the pos+ cable of the battery if it dies your alternator is bad if it stays running take it to autozone have then test your alternator to see what it's charging at
and post your findings
1994 Honda Civic hatch-DD
1991 Integra sedan-RIP
"Without the DA, there'd be no B-series or VTEC -Honda Tuning"
Offline sohc-civvi
« Reply #3 on: February 16, 2013, 10:57:19 PM »
or check your grounding to your tranny... if your starter doesnt have a good ground it wont turn over....
grounding is just as inportant as power.
Offline WhiteRussian
  • Forum Noob
« Reply #4 on: March 17, 2013, 10:14:07 AM »
Make sure you have the right battery, and check your flywheel for damage, and try to spin your motor to make sure its not seazed.
