Author Topic: alternator selenoid fuse problem need help  (Read 4990 times)
Offline Julio-ef7
« on: June 19, 2015, 02:47:19 PM »
Hey guys I keep having this problem I was driving in the freeway and out of nowhere my car turns off, check the fuse and it's the alternator solenoid fuse I changed the alternator and still does the same thing, it only does it when I drive in the freeway any ideas what could it be.....?
Offline slowass_EF
  • Flying Coconut
  • #TokoUso
Re: alternator selenoid fuse problem need help
« Reply #1 on: June 20, 2015, 07:06:58 AM »
By your screen name I'm guessing its in an EF?
Stock fuel pump?
I've heard of peoples fuses blowing after upgrading to a walbro 255 pump due to it drawing more amperage then your stuck pump. Most people fixed their problem by upgrading from the 10amp fuse to a 15amp fuse or just hardwiring it.
Could also be a short in your wiring, exposed wires grounding out maybe?
1989 CRX HF
1991 Civic Si
1988 CRX DX
1993 Civic EX Coupe
1997 Integra LS
1995 Integra GSR
Offline Julio-ef7
« Reply #2 on: June 21, 2015, 08:19:04 AM »
  :D yeap it's a ef and yea I got it fix it's was a wire makin contact with ground( metal) thank s for the help....  :D
